Author Topic: New playlist not showing up until next restart when using "Import Playlists"  (Read 1034 times)
mrasb
Whenever I use "Import Playlists" command from the file > Playlists menu to import a new playlist which is already saved on the disk, the imported playlist does not appear among other playlists. You have to restart the application to see the imported playlist. Could you please fix this problem in the next version of MusicBee. I'm using version 3.0.6132 on Windows 10 64bit.
Is it possible the newly imported playlist is at the bottom of you list of playlists? I recall a bug where that was happening with newly created playlists and this sounds somewhat similar. If you find that to be the case, install the latest patch and that should take care of it.
