Hey Steven,
just wanted to let you know about a bug that happens from time to time after a song finishes and the next one should start playing.
The size of the playlist does not seem to have any influence in when the error occurs (tried one ~800 songs and with ~70 songs).
So I was listening to some tunes and suddenly MusicBee stopped playing.
Wondering what happened, I tried skipping a track, starting/stopping playback, starting another playlist, and a bit more of this and that.
In the end I had to restart MusicBee, to get things working again...
Noted, that I had to use the Task Manager to kill the process of MusicBee before I could start it up again.
It does not exit the process on it's own if the close button of the window or closed via the menu in the upper left corner.
Sadly enough, there is not even an error log that I could give you to look at.
Whatever it is, it seems to crash before anything can be written to it.
I already tried it with a clean settings file without changing something: still happens
Hopefully this is in any way helpful in finding out the culprit
greets Shadeblast
