Hallo,
I've downloaded and installed this app today (therefore I have the latest release)
App seems great, although I've already found a bug
When folder is continously monitored and just copying the songs into it, MBee marked one of the songs as corrupted (of course that is not corrupted) - probably it scanned the song when the copy was in progress (?)
Bee did not removed the exclamation from the file later on its own.
Solution suggestion: maybe should watch/be aware files/items that are opened by other threads here and check them later or just skipping these files at that "refresh round" and processing them later
workaround was: moving the file to another subfolder
thank you,
J
