Hello,
Since a few days I cannot use MB anymore if I want to play music from my library.
Even after applying the newest patch of Jan15 (3.0.6224) each track stops in an endless hickup after around 3 seconds.
One time I saw a message that the audio device was locked up (or something like that) and I was advised to restart MB.
With the same result, however...
With other players outside MB there is no problem.
These are the newest error log messages:
16.01.2017 19:04:00 - X:\MB ORIGINAL\! MUSIC\:Thread was being aborted.
16.01.2017 19:07:31 - X:\MB ORIGINAL\! MUSIC\:Thread was being aborted.
16.01.2017 19:41:29 - X:\MB ORIGINAL\! MUSIC\:Thread was being aborted.
16.01.2017 22:05:40 - 6.1.7601.65536 - 3.0.6224.39247 - #=qQchOs9Qam2jixOzOiZQZVVcW5TguQZZUDeiy91T04Fb33oQZmHCfukaJvS2EAgJc: Exception of type '#=qQchOs9Qam2jixOzOiZQZVVcW5TguQZZUDeiy91T04Fb33oQZmHCfukaJvS2EAgJc' was thrown.
at #=qczuRJlV0i05najoo$HZgsxc1csf4OhnWldqJxrc9HGk=.#=qOm1BRScHYzt1yIpKGY8d7w==(Boolean #=qCPNFzCDRuJWJQmY8jRN90w==, #=qBIKnE$4cMuxSPJid1AAkuNvgwNScC9krUyCk9KCtTLo= #=qCkkH0$R9yGe4T2iJjhVOkA==, Int32 #=qQP6HF6ksYlWU1t2fSZiRKM5$EWu2lrcMX1BXGthq7cQ=)
at #=qczuRJlV0i05najoo$HZgsxc1csf4OhnWldqJxrc9HGk=.#=qpbHQYoZVDcVM9iwkn2DSJA==(Boolean #=q3JXbwiIoWO5Ubf0QkLnKqJcIqFigP89lS3djAGc8qVs=, Boolean #=qv$qKcS8FAaq_6wVF84qkrxqWiyzmtCZyiGHsOmM6fBw=, Int32 #=qdcA5_ET6icDJX31f2cPeNWlOuV5b02beUu2fPt918gM=)
at MusicBee.Media.PlayManager.#=qwgUdf4_Bd1xZKVf0yGeycVHYYjMbSiwcFwRn5JGmmtE=(Boolean #=qqtvIuTJmhxzzMNUtEjpCow==, Boolean #=q1QeT04wubF41Jld2U9Q7NRjN0DQ351GHns2alcyhF24=, Boolean #=qvwpwRaHAn3kC4MyKFUhGxHVdZuQZ4b75xKyeJw3XZr4=, Int32 #=qHL4tHlvYejZsdG5iZfxp9sB3s7xqQWAt4sUjU0XCJuY=)
at #=qgAgN0yD6QUw$ivGvlEsiH84b4XMN7Wr20vaDv3BV3nf_3kY51eMUCLsw0NJUIguw.#=qxGxVbmuTBrNcZPRNjfsMHGOaXqHLTmDUaLWjdDojubI=()
at #=q667WbFKCkIfd3KTGDsQMBpQQcxZaCPnysgLKHLRWsvmk4wmQvcbujxPrlQ5l7qXm.#=qvF$KhVAo_$wbJ99pr06EYw==()
16.01.2017 22:05:52 - 6.1.7601.65536 - 3.0.6224.39247 - #=qQchOs9Qam2jixOzOiZQZVVcW5TguQZZUDeiy91T04Fb33oQZmHCfukaJvS2EAgJc: Exception of type '#=qQchOs9Qam2jixOzOiZQZVVcW5TguQZZUDeiy91T04Fb33oQZmHCfukaJvS2EAgJc' was thrown.
No clue what they mean or indicate.
The last one may refer to my erroneous attempt to change the audio-settings of MB from DirectSound into anything else.
Help will be highly appreciated - as usual.
Thanks in advance!
Wim
