Author Topic: On the fly conversion, OGG missing  (Read 2781 times)
Shurikn
There's no OGG option for converting on the fly in my options.
I've installed MusicBee often on many computer, but I don't remember this ever happening.
It might be just that my memory sucks, or it has been removed in a relatively recent version?
How can I add it back?
  • MB Version: 3.6.8830 P
'Ogg Vorbis' should be the next one after MP3 in the drop down selection
Shurikn
Obviously, but like I said the option isn't there.
Do you have it installed/enabled? Check Preferences > File Converters.
If the location field is empty, it's not installed. If the OGG Enabled tickbox isn't ticked, it's not enabled.
oggenc2.exe should be in the Codecs directory under the MB directory.
Shurikn
Ok so, I went in that window, and it was already there and enabled, but I reselected it anyway, and applied, and restarted, now I see all the other formats. Not sure what happened but now it's working, thank you!
Sometimes computers work in mysterious ways. Glad it was that simple to fix.
