Author Topic: Location of Edit Playlists Window/Panel  (Read 3218 times)
I guess I missed a recent change.
My playlists are in the left sidebar navigator. If I right-click > Edit Auto Playlist, a floating edit window pops up over the main MB window. I like this behavior. If I do the same with a static playlist, the list of tracks opens in the right sidebar covering up the panels I have selected for that area. And I have to click the Settings button in order to edit the playlist. How do I get the old behavior back? IOW I want it in a floating window like Auto-Playlists behavior.
Bump
That change was part of the playlist manager enhancements.  I think it was supposed to be more like iTunes?  It sounded odd to me, but I haven't tested it much.
I never used iTunes so I wouldn't know.
So there's no option to get the Auto Playlist edit window to appear like the static playlist edit window? Too bad.
its been like that since the start of v3.1 but it is something i am also slightly uncomfortable with so i will look to change it slightly.
Please remind me if i havent done it in a couple of weeks though
Good to hear. Thanks Steven. Just wondering - is there a technical reason it couldn't pop-up in a floater as static playlist editing does now?
i have added a new right click command below Edit Playlist called "Edit Playlist Settings..." that has the old functionality
Thank you.
