Author Topic: so much bug for one day with bee... but bee the best:)  (Read 1149 times)
futh
MusicBee v3.0.6132.15853 (Win10.0), 13 янв 2017 0:26:
System.NullReferenceException: Ссылка на объект не указывает на экземпляр объекта.
   в MusicBeePlugin.Plugin.GetTrackCellIndex(Point pt)
   в MusicBeePlugin.Plugin.panel_MouseMove(Object sender, MouseEventArgs e)
   в System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
   в #=qTE0JcldJbgN5esU_qZLzhr_2sxBf$MFW$7qIAQBiuEk=.OnMouseMove(MouseEventArgs #=qiE0FKERQLtrpTj7X0VhtJw==)
   в #=qUycBT$mDJAAtlApdK7cKxC7bAOelaZARLejPWpHS_YU=.OnMouseMove(MouseEventArgs #=qeWyHP$GYpO0$iSapDhJuKQ==)
   в System.Windows.Forms.Control.WmMouseMove(Message& m)
   в System.Windows.Forms.Control.WndProc(Message& m)
   в #=qUycBT$mDJAAtlApdK7cKxC7bAOelaZARLejPWpHS_YU=.WndProc(Message& #=qMzWB776BHbVDTTwsWrsIYQ==)
   в System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   в System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
that is a bug with the last.fm similar artists plugin.
You need to re-download it and replace the existing one in the plugins folder
http://www.mediafire.com/download/dg2o1e9wnoky6ad/mb_LastFmRecommendationsPlugin_%28for_MB_V3%29.zip
