Author Topic: XML library export  (Read 1190 times)
cepilong
Hello!!
Thanks for this fantastic manager. So, one question and if the answer is no, please, treat it like the wishiest wish ::)
Is it possible to migrate from another library of another manager to MusicBee and mix the libraries?
I say... if I could convert my old library (from another manager) to an XML file (in i-Tunes format) and export my current library (from Musicbee) to another XML file, I could mix both files (with an external aplication), edit and unify duplicates and import the new XML file in i-Tunes format to a new library in MusicBee.
The only thing I would really need is a way to export a library in MusicBee to XML. Is it possible?
Thank u so much ;)
