Author Topic: error message when hitting esc while in full screen mode  (Read 1065 times)
dutchie
error message and report below:
MusicBee v3.0.6132.15853 (Win10.0), 10 Jan 2017 20:58:
   at MusicBee.MusicBeeMain.#=qWQ7nvtEI0rJKD1GW_nayWw==.#=qwqnxHlPCJGe7UawmvGfjvHqC36nt4o$JkCu$Sf6eUuI=()
   at MusicBee.MusicBeeMain.#=qWQ7nvtEI0rJKD1GW_nayWw==.#=qPukHmUKwLVX9A$9PEHiCeQ==(Boolean #=q03YJU8$49S5SGUw9hbBQRw==, Boolean #=qmBLiSiUXQJKXmtlZMTMg4w==)
   at MusicBee.MusicBeeMain.NavigationHeader.#=qNH7V3IP7W8uzGb6VISnt2g==(Boolean #=qrNnvUa_ZJTgY657EpRZJgA==)
   at MusicBee.MusicBeeMain.#=qJwqMzW7R75I5PbttNt$TTw==(Control #=qQjJzrS7ltyul8O1mD_CwHQ==, Boolean #=qH_8ZhDv_PyiXoVtmO9XBFsYHEuA7M9x2$exFVz_bzUY=, EventHandler #=q70SWNKisQwIRQDJNRze0iQ==)
   at MusicBee.Plugin.#=qVCTjVqeqSqXiPca1FQhNkTALWZWRVyd8MZHPeyFyPBU=._Lambda$__0()
   at MusicBee.MusicBeeApplication.#=qiztib$5cxlh0IrYx0CShHQ==(MethodInvoker #=qDaiCDBUAh2tcHGsgzyvhug==)
   at MusicBee.Plugin.#=qT1h5tQJ29R$vEJ4HmdFmyg==(Control #=qqbD0W785VIiQTQ8_JT7ZeQ==)
   at MusicBeePlugin.Plugin.TheatrePanel.Close()
   at MusicBeePlugin.Plugin.CloseTheatreMode(Boolean dispose)
   at MusicBeePlugin.Plugin.TheatrePanel.OnKeyDown(KeyEventArgs e)
   at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
   at System.Windows.Forms.Control.ProcessKeyMessage(Message& m)
   at System.Windows.Forms.Control.WmKeyChar(Message& m)
if this issue becomes problematic for you i suggest you try the latest v3.1 beta
unzip into the folder MB is installed
