Author Topic: Auto-Playlist Field for Rating Date Modified  (Read 1747 times)
Xenatier
There are currently methods that almost do what i'm trying to achieve, i have an auto-playlist that has tracks that are 5 star and added within the past month but that doesn't include songs I've had in my library for longer than a month that I've recently rated. Also using the date modified field doesn't always work if i change things like the lyrics, genre, artwork, etc
Would it be possible to have an auto-playlist field for the date a tracks rating was changed? Allowing you to create a playlist with songs you've rated in the past month.
vanhoivanbinh
You can use "recent modified" and "rating" function in the autoplaylist to short out the songs you want
