Musicbee newbie here. I'm so happy to have found this software. Thank you for the its development!
I've been going through my tracks attaching missing tags, and the one thing that kills me is the Mood and Occasion tag input format.
If you want more than 1 tag assigned to a track, you need to type the new tag, separated by ;
I'm probably trying to progress through all my tracks too quickly, but if I mistype a tag, it adds it as a completely new tag (and it makes sense why it would do so). So if you already have "Aggressive" in the system but accidentally type "Agressive" (or whatever accidental spelling combination), MusicBee will now have both "Aggressive" and "Agressive" tags saved into the system.
I'm wondering if there's a way for those fields to behave like the Custom tag fields (Multiple tag splitter), WITH a drop down suggestion list?
So you would be able to either type your tags OR open up the tag splitter.
As I was typing this, I think I understand the reason why you chose a drop down list instead of the splitter: the tag suggestion feature of the drop down.
Anyways, if this is possible, I think it would be fantastic! If not, I understand there are probably limitations that I'm unaware of on a probably very seldom-used set of tags.
Thank you for the great software, and I understand my request cannot be done.
- T0X
