Author Topic: this is what android needs  (Read 1270 times)
pete88
This can be so much more. I wish there was an easier way to sync to android phones for instance search mtp devices should be checked from when you first download and there should be a tutorial on syncing to sd cards on phones because I had trouble but figured it out I had to make a folder on my sd and manually write it in the settings portion under path most people are not bright or lazy and would just delete the program. but I been looking for an iTunes equivalent and this could be it especially if there was a tab to purchase music. there should also be more advertisement for this I think all android users can benefit from this software.
