Author Topic: Changing the track title, text clipping  (Read 2736 times)
Chaython
Not sure if this was a bug or added on purpose, but I don't recall having it before, the title will show 5 and a half characters with the text box overlapping it. It kicks my OCD. This then also clips the text box over top of the track length.
The latest MusicBee patches.
CritterMan
  • Now with FiiO M11!
Duplicated with 3.1.6196 on Win7 x64.
That is not a a bug. I am pretty sure you have enabled 'enable direct editing of tags in the main window', and then double clicked the track in the extended panel.
CritterMan
I think he was referring to the position of the text editor box in relation to the displayed title.
Yes, I see. I stand corrected, I didn't read the title, only the post.
When you try to edit fields that way, that indeed does display a little bit awkward.
Last Edit: January 03, 2017, 06:31:46 PM by hiccup
scartez
Chaython
