I just downloaded the latest patch of MusicBee and installed it per the directions. When I try to run it on my Windows 10 box, it doesn't start.
I see that the "Before You Post -- Read This" says that I should send the "Help/ Support/ View Settings File". Is this a directory tree under something? If it's a menu path in the interface, I can't do it, because the interface doesn't start up.
