Hi. MB is outstanding, and keeps getting better.
But one feature that previously worked smoothly does not appear to be doing so now -- with the latest update 3 (incl the patch files), playlist folders only work at the top level, they don't nest anymore.
The playlists aren't lost, and the desired structure is maintained in the [Music\Playlists] folder. But they all render in MB as [former subfolder name\playlist name]. This is happening on different machines with different Windows versions, so it doesn't seem to be a machine-specific or configuration issue.
>> An somewhat similar issue related to nesting playlists was noted in an earlier bug post, which was responded to as Fixed in version 3. But it seems to have reverted. Or is there a command that I've missed? Is/was there a playlist setup page in Preferences?
Another thing, the Wikia article on Playlists mentions a feature called "display using view" -- this doesn't seem to be enabled now. It would be quite a useful feature. The column display format can be replicated by duplicating a playlist then editing it, but if any changes are needed across multiple playlists then they have to be manually edited. It would be great to have a default view that can be edited, and changes introduced individually as required.
Thanks.
