this is half bug, half feature request...
As is - MusicBee uses relative paths IF the media files live on the same HD partition, and there is no way (afaik and I got no replies on asking this exact question) for a user to switch to absolute paths (in library, and exported playlists...) other than to move the MB / the program to a different HD partition, which might not always be possible.
Not urgent (for me), as I now have moved MB & re-located the libraries again.
Cheers.
c.
