I plan to make the following changes to auto-playlists:
- when the number of rules exceeds 8, the panel will be scrollable ie. for playlists with a large number of rules, you will no longer be constrained by your screen size
- for nested rules, the current behavior is to always use "and". Sometimes it will be useful to use "or" instead so i plan to add a drop-down for that
- already done was the ability to select multiple library filters
- if there is anything pressing you think needs to be improved with auto-playlists now is a good time to comment
