Note to the staff: Please join and idle in the channel, without developers and moderators, the effort will be unproductive. If you need free bouncers, check the bottom of the post
Also, if you gonna idle, you will have to state your Freenode nick so that permissions (privileges) can be set accordinglyHello,
Every FOSS project has an IRC channel, gives project wider recognition in the geeks community and facilitates live support and discussions. Freenode is the largest FOSS supported network with over 51,000 channels and 1,50,000 users.
Freenode is for both, free and open source, while Musicbee is not open source but it falls into the category of free.
For this purpose MusicBee's IRC channel is set. To join type
#musicbee on
irc.freenode.net at port 6667, 6697 (SSL)
If you need help using IRC or idling in the channel, please reply in the thread.
Click here for the list of Free IRC bouncers (ZNC)P.S I've acquired a shell to host a bot to maintain the channel and carry out the day to day operations. I don't know scripting so I'll have to find someone to script it. It will take sometime to be online and operational.
P.P.S If the owner is Ok with the move, I'll keep the channel online for a month to see if it generates any interest or else I can't sit in an empty room for eternity and gaze the walls.
