Author Topic: Full customization "Header Bar"  (Read 3520 times)
Sofocl
1. Ability to remove a gap of a few pixels above the tabs; Implemented!
2. Ability to remove the inscription "MusicBee" (Leaving only icons) and the buttons "Forward", "Back", "New tab", "Configure Layout", "Minimize", "Restore", "Close" ability to remove, or to place a "search Box" in any order .
3. Ability to add custom buttons to the right and left of the tabs (Now only the right).
4. An expandable "Search Box"; Implemented!
5. Ability to hide the search field in the icon;
Last Edit: September 10, 2020, 01:42:31 PM by Sofocl
Sorry for my bad English.
Sofocl
Sofocl
for v3.1, 1 & 4 are done
1 point must somehow be turned on or it is not ready yet?
Is it possible to narrow down the search field stronger and move it closer to the buttons?
Lots of space in vain idle can be clearly seen with the dark theme:
Last Edit: March 20, 2017, 07:43:31 AM by Sofocl
Sofocl
Phantom visual glitch;
Regarding item 1, it's made you write but how to enable it?
Last Edit: March 20, 2017, 07:44:42 AM by Sofocl
