Author Topic: Source files for the bundled skins?  (Read 2815 times)
Nokiaman
I wanted to do some small edits to WMP12.xmlc, but as far as I can tell it's compiled. Is the source available somewhere?
Bit-mapped skin files (*.xmlc) can not be edited by the end user.
Nokiaman
I am aware, but there has to be source somewhere as they seem to be compiled with that Skin tool.
You should be able to find a thread for it on the skins forum.  If the author hasn't already posted the source, you can ask for it.  However, if you don't get a reply you're out of luck.
Nokiaman
Hmm it appears you are right. There is indeed source here. I didn't know that bundled skins are made by users.
http://getmusicbee.com/forum/index.php?topic=6207.0
