Author Topic: Question about filter panel  (Read 2969 times)
Alumni
I noticed that when the thumb browser is docked to the right of the column browser it inherits the elements contained under id="FilterPanel", instead of the usual id="ColumnBrowser". I'm not sure if this is intentional, but it means I can't for instance enable alternating row colors for the column browser without the thumb browser also inheriting those same values.
the way it should work is if the filter panel colours are defined, they will be used no matter where the thumb browser is positioned.
Otherwise the alternate row colour for the track detail view from the main panel is used.
If its not how i say, could you send me your skin so i can see for myself
