just want to share, that I managed to get MusicBee 2.4 running under OSX using PlayOnMac (
https://www.playonmac.com/en/).
Probably 2.5 will work as well; I just did not try.
Steps:
- Install PlayOnMac
- Run PlayOnMac
- Install a program -> Install a non-listed program (bottom left) and follow the steps, keep all defaults.
- Make sure, to not tick the box to run the program after MusicBee installation is done.
- When installation is finished, select MusicBee in PlayOnMac and choose Configure -> Install components -> dotnet40
- Once that is done, you might want to create a desktop shortcut, again select MusicBee -> Create a shortcut and follow the steps.
- Now MusicBee should start when double-clicking on the new desktop shortcut.
Notes:
- MusicBee 3.x does not work with PlayOnMac. It gives error, that MB is not running under Windows XP :-(
- Some Skins will not work. If selecting such a skin, MB will not start anymore.
PlayOnMac creates a folder in the main users directory, name PlayOnMac. . .
In that one finds the new application (e.g. MusicBee) -> drive_c -> users -> [username] -> Application Data -> MusicBee
I copied all data in that folder as backup. If MB does not start after any configuration changes done, I just copy the data back, and it starts again with
last working configuration.
I use skin Dark-MidnightMetro and that one works.
Despite some limitations (skins) and some random crashes it works very well and I am happy, that this excellent player is running under OSX.
Of course, would be even better, if 3.x versions would run as well, but 2.x is good enough for me.
