Author Topic: $LCut & $RCut functions  (Read 5665 times)
theta_wave
Use case: I created an external tool entry for CUETools.  Essentially, it is C:\Program Files\CUETools\CUETools.exe "<Path>" (application_path and parameter respectively).  However, the terminal "\" messes up CUETools, e.g.  CUETools.exe "D:\foo\" doesn't work whereas CUETools.exe "D:\foo" does.
I believe a function that cuts the number of characters a user assigns while returning the rest of the field will fix his issue,  e.g. $RCut(<Path>,1).  Basically, it is the opposite of $Left and $Right functions.
Thus, the working CUETools entry will be C:\Program Files\CUETools\CUETools.exe "$RCut(<Path>,1)".
This is nothing critical, just something that would add convenience for me and, hopefully, for others.
Note: I hope this doesn't confuse users of the cut command so often used in bash scripting.
Last Edit: June 03, 2016, 08:54:58 PM by ssri
Am I late to the party?
Recently I had a little challenge where I was looking to do exactly this.
It was resolved in a slightly more complicated manner, but this would be nice to have.
+1
The Incredible Boom Boom
The Additional Tagging and Tools plugin has $CutLeft() and $CutRight() functions.
