Author Topic: Mini-Lyrics Support  (Read 28960 times)
***** This plugin is redundant now - Crinsoft (the makers of minilyrics) have a plugin that integrates with musicbee ******
- just install the latest minilyrics program from http://www.crintsoft.com/dl.htm
you need to have the mini-lyrics application already installed
and requires MusicBee 1.2.3908+
copy this zip file to where MusicBee is installed and unzip:
you should have:
c:\program files\musicbee\MLPlugin.ini
c:\program files\musicbee\Plugins\gen_MiniLyrics.dll
then edit MLPlugin.ini and change it to point to where mini-lyrics is installed. You just need to start MB and it will detect the 2 files and automatically invoke/interact with mini-lyrics.
You can hide/show mini-lyrics by right clicking the Now Playing panel in the right sidebar and toggling 'Show Mini-Lyrics'
Last Edit: December 29, 2021, 02:50:44 AM by Steven
Tschako
Good it gone but its not freeware ... pity ...  ;)
on/off button in Musicbee ?
jackuars
account4me2
Just a hint for Windows 7 (and Vista?) users:
--the above point is very important - by default, MiniLyrics is installed in "C:\Program Files (x86)\Minilyrics\" NOT "C:\Program Files\Minilyrics\"
----if you don't change that in MLPlugin.ini, you'll get the error: "Can't find MiniLyrics.dll, Please reinstall MiniLyrics!"
greenday1987
  • Long live OiNK!
Works great, thanks a lot  :)
RIP OiNK
Havokdan
Minilyrics 7.1 beta out, Musicbee dont working in this version. :(
the mini-lyrics developer replied to me and said he will add support for musicbee, although he didnt give a timeframe or an indication to what extent the support will be
ma_t14
I guess my nagging emails helped after all  ;D
sierena
Thank you! this is like a dream came true.
Thank you so much! I actually re-installed minilyrics few times because of this message.. not knowing I have to change the path.
Tapar
I know the plugin is redundant but I have a old version of minilyrics that does not support musicbee.
Could you please reupload the plugins? The links are dead.
