Hello everyone,
(I'm curently learning English, i'll try to be clear)
Until it is fixed. I have made a little program in c# for copy the iTunes Music Library.xml utf8 Without Bom.
https://drive.google.com/file/d/0B8qjLXuhQ1fIb3M3UmFVN0RqdDQ/view?pref=2&pli=1Place the "MusicBeeToTraktor v0.3.exe" on the same directory that the "Tunes Music Library.xml ". click on "MusicBeeToTraktor v0.3.exe"
it will create two files
- iTunes Music Library For Traktor.xml (Config traktor itunes library to this file)
- iTunes Music Library Back.xml (Do not use this one, but don't delete this one)
Just launch "MusicBee Traktor v0.3.exe" always after close MusicBee and at anytime when you need to use in traktor.
I have use this function in c# for fix
new StreamWriter(FILENAME, false, new System.Text.UTF8Encoding(false));
Best regards,
Melo
