Author Topic: decompile bitmap skins  (Read 6858 times)
  • MB Version: 3.6.8849 P
Is there any way to decompile or disassemble an .xmlc skin to extract the skin file, if I have the source skin originally used?
i would need to write a program to support that
sent you a PM
would be so helpful and greatly appreciated if you could possibly find time to do that :)
received your PM's
you are an absolute life saver :)
thank you very, very much!
Tommy
....... is it possible to share this decompiler with the rest of the community ?
Tommy
Sorry, but Steven never made the decompiler.
He was able to give me a text dump that contained the skin.xml file that I used with the SkinCreator and a source .xml file to create an .xmlc skin I had already posted.
Tommy
....... never mind, thanks anyway.
BTW, I found a SkinCreator and sources for Metro Skin on the internet, but it seems to be very old.
I think it's from 2012 and I wonder if there is a newer version available.
Could not find anything on the MusicBee website, only a dead link.
Maybe you can point me in the right direction.
Thanks again .......
Tommy
Try an advanced search for "metro" in the Skins sub-forum.
Last Edit: February 18, 2017, 09:39:18 PM by phred
Tommy
....... just tried, but could not find anything other the one I got Metro Skin v3.5 Flat.
Did I miss something ...?...
Tommy
I did a search on an old drive of mine, and did find some 'Metro' skin stuff.
I have no clue if it's useful to you, or how recent it is compared to what you already have, but here it is:
https://1drv.ms/u/s!AkA0tSv_UzTAgnq-8gGHkqJ4PqSf
Tommy
....... thanks for your replies.
I did get the sources for DarkRed after I contacted endeavour1934 via p.m. but without the SkinCreator.exe.
Just the images, the skin.xml and DarkRED Flat.xml.
The files I got from hiccup contained the same SkinCreators I already got, but I still do appreciate the effort.
Just wondering why the SkinCreator is not officially available for download anymore.
Any particular reason for that ?
Anyway, I think I've got enough to play around a little, just created a complete player icon set which I'm going to implement now.
Would be great if one could use SVG files, but PNG's are fine as well.
Like the MusicBee player a lot compared to Foobar2000 which I was using before.
Thanks again and I definitely will be back seeking some advise from you guys .......
Tommy
