Author Topic: The Blue Bee and the Sea  (Read 28185 times)
Roadrunner
Hi hiccup!
Thanks for giving it a try (sorry, pressure was not intended ;-) ). I like your international version (with the right line in K-form like the text version), I would definitely use it!
Just to show what I meant this morning (just a quick draft), but your international example is probably better...:
Updated the skin with new player controls.
I followed Roadrunner's suggestion to use icons so to keep it more universal:
(the download link is in the start post)
Thnx, I am happy with the result too.
But I am not quite satisfied with the shuffle/repeat/volume buttons, so hopefully someday some inspiration will hit me for those, or perhaps you or others have suggestions for those...
A couple of minor oversights were fixed.
The download link has been updated.
updated
(and probably final for MB v3.1)
the download link is in the startpost
  • MB Version: 3.6.8830 P
found this tonight
(isn't it usually "greenies" on your skins?)  ;)
Thanks!
Yes, those used to be greenies indeed.
Hm, I'm probably a bit less consistent then I thought I was ;-)
(on second thought, for this skin I probably used some other skin of mine as a starting point, which had a red iconmask, and then I missed modifying it)
Updated.
Fixed an anomaly when tabs are located in the caption bar.
(thanks Bee-liever)
Rodi
I only registered to say: this skin is absolutely fun and amazing.
Thank you for it!
