Author Topic: Skinning requests/reports for 3.1  (Read 145902 times)
For whenever you get to it.  :)
*could the search icon also be a different color when the search box is active, like the text?  Picking a color that works for both is hard if they're very different.
*could we have the window button highlight cover the whole height of the caption bar, like native Windows 10?
*full overrides for Music Explorer and the Panels Configuration window (and new downloads panel)
*icon override for the folders in Playlist Manager
*consolidated command buttons respond to mouseover like they do when not consolidated
*better elements for the tag editor
*overrides for separator element between tabs for stacked element (both in header bar and elsewhere).  Maybe full overrides for tabs?
*alternate Tabs Bar background when the library header bar is hidden
*slimmer, rounded background for podcast and inbox counters
Last Edit: May 09, 2016, 03:59:39 AM by psychoadept
Iasc
When you revisit skinning could you please implement a fade effect for
"NowPlaying[AlbumAndTracks].AlbumSeparatorLine"
"Content[AlbumAndTracks].ItemSeparatorLine"
"Content[TrackDetail].ItemSeparatorLine"
  • MB Version: 3.6.8849 P
when using the "MainPanelMargin" elements and the player is in the top panel, a line is needed to close the top of the header bar
I suggest
<element id="PlayerTopFlat.BaseLine" bg="xxx,xxx,xxx" />
and probably
<element id="PlayerTopFlatBLMargin">1</element>
to allow it to be matched with different panel margin widths
- bg & fg of high/lowlight selector for artwork expanded panel when auto-pick color option is disabled
- slider line for input panel
- volume slider line for main player
- full overrides for narrow/wide mini player
- the unskinned 100,100,100 border of small popup window from tag inspector: http://i.imgur.com/D3Wa67r.png
- default icon support issue: http://getmusicbee.com/forum/index.php?topic=16643.msg110200#msg110200
Last Edit: April 30, 2016, 07:38:45 AM by redwing
The playing/selected button draws it background colour automated.
When the childheader bar has a subtle gradient, that results in a strange differentiating gradient for that button.
Therefor this is a request for an overrule element for it.
This is a request for an element or an icon overrule for the check ticks in the Configure Layout panel.
Alumni
If possible I would like to see these skin overrides for the next version;
1. Panel configuration window - background color which appears behind available elements.
2. Analyze volume window - replaygain slider color and interactive button color.
3. Main player volume control - full/empty slider bitmap image support.
4. Preferences window - drop down menu arrow mouseover color.
sleepless
I requested this earlier, but I think I posted it in the wrong thread. Would it be possible to enable a border for element id="Panel.Body.Lowlight" ?
It's already enabled for these:
  element id="Panel.ChildBody.Lowlight"
  element id="Content[TrackDetail].Body.Lowlight"
  element id="FilterPanel.Lowlight"
  element id="ColumnBrowser.Lowlight"
I feel the skin will look more consistant if this element has a border also. (Unless it already does, but is not being displayed for my skin, in which case please let me know). Thanks.
Iasc
Can we have an override for the no rating icon ( the bomb ) when skinning is revisited.
Thanks
i have added
   <element id="Panel.TabButton.Default" bg="255,0,0" bg2="128,255,10" fg="255,200,200" />
it will be in the v3 final release
GIF of some funky behavior of the tabs when clicking the selector: http://imgur.com/ddRzXAu
Important points: shifting of the divider line, and duplicate divider line.  (Would be nice to be able to recolor the divider, too.  It doesn't look very good here.)
This is an observation on something that has been a skinning challenge from the early days of MusicBee.
When an icon has transparency values and colours that match/collide with highlight colours of selected fields (and also on active tabs), these icons can loose their recognizability.
There are probably a few possible solutions for this, such as perhaps alternative icon options for 'selected', or some inverted 'masking' feature?
Or maybe a skinning option to make the (16x16?) area of the tab or the selection bar where the icon is positioned transparent?
Alumni
From my recent skinning experiences, the following overrides or new elements would be useful;
- BG color of the device information panel in the sync node (currently taken from childbody).
- BG color of the header section of the upcoming releases and concerts nodes (currently taken from left panel?).
- BDR color of the outline in the preferences window (currently taken from left panel border).
- BDR color of highlighted vertical menu items in the preferences window.
Another suggestion: a toggle for closed highlight/lowlight borders (ie. vertical and horizontal outline).
Last Edit: May 23, 2016, 12:52:08 PM by Alumni
<element id="PlayerSplitProgressYOffset">Above</element>
was introduced for 3.0 to place the values above the progress bar
could <element id="PlayerSplitProgressYOffset">Below</element>
be added to place the values below the progress bar, when it's used as the top-most element in the player bar
(refer to my Rain skin if you need a visual of what I mean)
could element id="NowPlayingList[TrackDetail].ItemSeparatorLine"
be added to the NowPlayingList[TrackDetail] overrides please.
