Author Topic: Absolute Zero  (Read 13352 times)
Iasc
Absolute Zero
INSTRUCTIONS
[1] Download the file
[2] Unzip it in the MusicBee Program Files/Skins
Icons designed by endeavour1934.
sarah777
Awesome skin, i love it. Thank you!!!!!!!!
Iasc
Your welcome. Glad you like it.
Iasc
Fixed problem with lastfm love. Download link in first post updated.
Iasc
Fixed a few small oversights. Link in first post updated.
Iasc
jackuars
Can you export your settings and post it here. I would like to set MB like yours :) It's amazing.
Iasc
My setup has changed since i took that screenshot, its like the picture below now. Anyway i vaguely remember  a post by Steven not to long ago giving a reason why its not recommended to share settings on the forum, i cant remember what it was though.
Iasc
Iasc
Updated with new skin elements and some fixes.
bege
Hello,
I guess this is not intentional:
With the blue skin Absolute Zero the menu entries in the title bar (file, edit... help) are invisible without hovering over them. The respective entry in the xml file makes foreground equal to background of "MenuBar.Default".
I changed the entry from
<element id="InlineMenuBar.Default" bg="0,100,0,0" fg="1,20,55" />
to
<element id="InlineMenuBar.Default" bg="0,100,0,0" fg="210,210,210" />
Last Edit: May 31, 2022, 06:33:29 PM by bege
