Author Topic: Crackling noise in ASIO in MB3  (Read 2861 times)
Chaython
THe exact same playback settings in MB has no audio corruption
but in MB3 these settings sound good, then grow more gargly and more until all you hear is artifacts, No matter what buffer or sample you set it still happens and setting to 20ms does however delay how long before it start happening, but I can only play like 3 songs before it happens,,, reverted back to 2.5 for now
The latest MusicBee patches.
nothing has been changed with ASIO output for v3 so i wont be able to help
Chaython
It's probably related to the new buffer settings, it's now a slider, and before it was a check or uncheck, within MB
But no matter what I set the slider to it doesn't improve the situation.
new https://i.imgur.com/dn8oa6d.png?1 vs old https://i.imgur.com/0cm8tmG.png?1
Chaython
I don't recognize any other changes... That would cause this, but I see there's a much more detailed topic here: http://getmusicbee.com/forum/index.php?topic=17605.0;topicseen his issue seems to be very similar to mine, except only MB3 does it
As to not leave out details, here is my dxdiag
https://drive.google.com/file/d/0BzGkUl2NWdXiQ2pFdGlFdk91Z2c/view?usp=sharing
Looking at commonalities between our specs, I'm wondering if it could be related to NVIDIA High Definition Audio, as this issue only occurs on my HDMI and not my headphones
Last Edit: February 18, 2016, 01:10:53 AM by Chaython
