Please bear with me here as I'm completely new to this stuff. Could someone explain why it is that when an object is anchored to the panel edge, a constraint works fine. However if the anchor is the Panel.Center or a Panel.% the constraint doesn't work (object extends all the way to the end). Here's 2 examples:
1. works:<element type="Block" xAnchor="Panel.Left" x="0" yAnchor="Panel.Center" y="0" widthDock="Panel" width="-50" height="20" bg="250,0,250" ></element>
fails:<element type="Block" xAnchor="Panel.Center" x="0" yAnchor="Panel.Center" y="0" widthDock="Panel" width="-50" height="20" bg="250,0,250" ></element>
2. works:<element type="Block" xAnchor="Panel.Center" x="0" yAnchor="Panel.Top" y="0" width="20" heightDock="Panel" height="-50" bg="0,0,250" ></element>
fails: <element type="Block" xAnchor="Panel.Center" x="0" yAnchor="Panel.20" y="0" width="20" heightDock="Panel" height="-50" bg="0,0,250" ></element>
Here are the 2 that work:
and the 2 that don't:
This issue is causing me a lot of problems in trying to create a new TM.xml. Any help here would me much appreciated.
EDIT:
I realized that using the prefix X: or Y: when setting the widh/heightDock value works, BUT if there is an align="" command (the sme element from the opposite side panel), the object doesn't appear at all.
works:<element type="Block" xAnchor="Panel.20" x="0" yAnchor="Panel.Center" y="0" widthDock="X:Panel.Right" width="-50" height="20" bg="250,0,250" ></element>
fails: <element type="Block" xAnchor="Panel.80" x="0" yAnchor="Panel.Center" y="0" widthDock="X:Panel.Left" width="-50" height="20" align="Top.Right" bg="250,0,250" ></element>
