Welcome, Guest. Please login or register.
May 22, 2013, 02:42:05 PM
Login with username, password and session length
40782 Posts in 6142 Topics by 4633 Members
Latest Member: mintyminty
* Home Help Search Login Register
Search:
+  getmusicbee.com
|-+  Support
| |-+  How-To's
| | |-+  Set up VideoLAN VLC Player for video podcasts inside Musicbee
« previous next »
Pages: [1] Print
Author Topic: Set up VideoLAN VLC Player for video podcasts inside Musicbee  (Read 1343 times)
ild2
Full Member
« on: August 23, 2010, 04:34:50 PM »
1. Install VLC
2. In Musicbee goto: "Preferences -> Player" and point Musicbee to the VLC executable and click "save"
3. You can now right click any podcast entry inside Musicbee and select "Play with Vlc" - it's not finished though. You will find that the playback stops repedetly to refill the buffer.
4. To fix this:
- start VLC
- go to "extras -> settings".
- select "Show settings -> all" in the lower left corner of the settings window.
- go to "Input/Codecs -> Access-Modules -> HTTP(S)
- change the "Cache value in ms" to something a little higher, like 4000.
- check "Continuous stream" and "Automatically reconnect" and save the settings.
Streaming of video podcasts should now work correctly without the rebuffering.
« Last Edit: August 23, 2010, 05:19:57 PM by ild2 » Logged
Pages: [1] Print
« previous next »
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2006-2008, Simple Machines Valid XHTML 1.0! Valid CSS!
