Author Topic: CohearentDark  (Read 17552 times)
Alumni
Edit: Skin no longer supported, please see its replacement here: http://getmusicbee.com/forum/index.php?topic=17549.0
Last Edit: February 12, 2016, 05:05:40 PM by Alumni
silvestreccf
Dosen't work in my musicbee, get a error the player dosent open!! do you know how to fix this.
A new bitmap based skin compatible with MusicBee v3.0.
Follow this thread for future updates.
Download: https://app.box.com/s/uaktjvzcnyrg0xi0uytlsb014n3wtwsk
Credits: Bitmap icons designed by endeavour1934.
Fonts: http://www.latofonts.com/
Click thumbnail for full size preview.
you would need musicbee v3 from http://getmusicbee.com/forum/index.php?topic=15050.0
skyrockman
What are the settings required to achieve the look in the preview picture?
Alumni
pietergdp
I really like this skin. It looks a lot (maybe even better) like a skin I was working on a while back and never got to finish.
Alumni
Thanks. This took me about a week to get right, but I'm happy with the result.
Please note: Skin updated, fix for artwork border color when grouped by artist.
MewCore
Would you care to add wave bar?
The wavebar is user-selected when using the "modern" layout.
In v2.5 Edit > Preferences > Layout (2) > use "modern" layout > wave bar
In v3.x it's in Layout (1) for displaying in the top panel, or click the layout configure button (to the left of the search bar) for other placement.
Last Edit: January 01, 2016, 06:05:14 PM by phred
mojo5040
I absolutely love the way the skin looks, so I decided to download it but unfortunately whenever I try to launch it I get this error
1/3/2016 9:44:18 PM - 10.0.10240.0 - 2.5.5804.26036 - System.ArgumentNullException: Value cannot be null.
Parameter name: image
   at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y)
   at System.Drawing.Graphics.DrawImage(Image image, Point point)
   at #=q2nBjYOTrTeaMjjog3pLrCfPGUcmOc_frEMQeYCouXSTSzBGNTb4Y0GCb87tnRn41..ctor(Boolean #=qGsKHgv2Je21iRLUcV5TljA==, Boolean #=qR9MmUJlnhYZTMbgvd$fhIQ==)
   at #=qP79FiVI5FhccbKAh7Z2Q0lNC2GNMYO8FmC1S8zUAISg=..ctor(IList`1 #=qL4YT3xlKF3ARgwia4_eQPA==)
   at #=qP79FiVI5FhccbKAh7Z2Q0lNC2GNMYO8FmC1S8zUAISg=.#=qPeyzkye7$yuU848tCEggWG9JnbLpvn0odRqaJoAa$7I=.OnStartup(StartupEventArgs #=qZHPfU5x28VEZVc9gW9PYIQ==)
I really hope someone will be able to help me.. also because I keep getting this error I can't even get into MusicBee anymore, do I need to re-install?
thanks in advance for any help, i need it
with regards
mojo
If you delete (or move) the skin from the skin folder, MusicBee will start-up using the default skin, and you will be up and running again.
