Author Topic: Tags removed from current playing song when moving to library  (Read 4111 times)
9cupsoftea
When I move an album from my inbox to my library everything will move fine, but if I'm listening to a track from the album while it's moving, that song will have its tags removed and be marked as 'unknown album' in the library.
I have the setting which analyses and adds replaygain tags when moving from inbox to library, and I think this might be the cause.
do you have your library auto-organised as well? and when the song was added to the inbox did it have any tags at that point ie. did you add the tags while the song played
edit: never mind - i am able to reproduce this. I think the only solution for v2.5 will be to stop playback but i should be able to something much better with v3
you can recover the tags using right click/ send to/ rescan files
Last Edit: October 23, 2015, 05:42:31 PM by Steven
9cupsoftea
Ok cool. I usually just retag the whole album again to fix it, but the rescan sounds quicker. Thanks for the quick response!
