Hello, so today I've decided to finally switch from iTunes to MB, I've imported my library and done my skin, my tags and properties were perfectly carried over ( things like play count... ), in short everything is fine.
So fine that I felt like renaming some album/songs and move them elsewhere to make it more clean.
But then the properties changed:
http://i.imgur.com/TDfEjJA.pngSo it's either by changing the location or renaming the file.
My question is: Are the properties not saved in the files ? If no then where is it saved and can it be backed up ?
Or perhaps a mean to keep them unchanged even when doing the mentioned things earlier ?
Thanks anyway
