Author Topic: Play TuneIn stations  (Read 10220 times)
RekoChett
**TUTORIAL DONE IN GOOGLE CHROME**
HEY!  So, after a little bit of trail and error, I figured out how to play stations from " tunein.com " with MusicBee!
• First off, I'll use the station that I used, which is this one > http://tunein.com/radio/ScreamoRadiocom-s144743/
• Once you're on that page, you're going to want to right-click anywhere and select "Inspect Element" or use either of the keyboard shortcuts "CTRL+SHIFT+I" or "F12".
• Once you open the that, press CTRL+F in the "Elements" section and look for "jp_audio".
• Look for the link to the right on the SAME line of code.  Should be the last thing you see.  Looks like "src=XXXXXX" where the X's are is the actual URL.  In this case, mine was "http://cc.net2streams.com:8557/;"
• Double click on that link (don't worry, it won't open anything).  It should select the thing you clicked on, because it's smart like that!  Copy that URL.
• Go to the Radio section in MusicBee and right-click empty space (or right-click the Radio button) and select "New Station".
• In the "stream url" field, paste that URL you copied earlier!  Make sure you tidy up the URL if needed!  In this case, we're going to remove the ";" at the end of our link.
"http://cc.net2streams.com:8557/;" -> "http://cc.net2streams.com:8557/"
• MusicBee should automatically detect and enter information when you click away from the text field, but just in case you want a different title and such, you can do that too.  (:
• Click "Save" then double click on the station you just added and ROCK OUT!  Or chill out..  I mean, you could be doing Chillstep or something.  :b
I hope this helps!  Thanks for this amazing music player!  (:
Edit 000: MusicBee Wikia page! Suggested by psychoadept.  (:
Clicky: http://musicbee.wikia.com/wiki/Play_TuneIn_radio_stations_through_MusicBee
Last Edit: June 16, 2015, 07:03:12 PM by RekoChett
Thanks for sharing this!  Would you consider making a wiki page for it, too?  You can find instructions here: http://musicbee.wikia.com/wiki/Category:Guides
You should basically be able to copy-and-paste your text.
Thanks!
holuschi
Another  possibility to play and save radio stations in MusicBee is using the station directory of MusicBee or  explore statons with http://www.internet-radio.com/     Here open PLS with MusicBee, play it and save it.
