Author Topic: Add-on Manager  (Read 76221 times)
  • MB Version: 3.6.8849 P
en.rtf's
Thanks boroda, will have another go.
Would it make any difference, speed-wise, if the plugin was split in to two separate plugins?
One for users to update their plugins/skins and the other for developers to use for maintenance of their work.
No. I'm trying to speed up plugin now, but wouldn't expect too much of this.
Next version released:
http://www.mediafire.com/download/iklj7nxtlotox3z/mb_AddonManager_2015-08-02.zip
  • Plugin speed is improved
  • FOR TESTERS: Try to install/uninstall customizations which definitely you have uploaded AND which definitely not you have uploaded.
  • TO DO: Add support for icons and theater modes, add number of active installations to customization tables.
Update:
http://www.mediafire.com/download/zmbv8a0hmq1bi8v/mb_AddonManager_2015-08-03.zip
  • Various bugfixes in Developer Tools. Please recheck Developer Tools again.
  • The number of active installations is added to customization tables.
  • FOR TESTERS: if you want to be able to access Developer Tools create empty file 'DevMode.txt' in 'Plugins' folder.
I want to remind that you can safely use regular google account (not specially created for this plugin).
Update:
Getting this error:
03/08/2015 4:38:38 PM - 6.1.7601.65536 - 2.5.5606.32711 - System.MissingMethodException: Method not found: 'StorageApi.StorageApiFile StorageApi.StorageApiFile.FetchAllFiles(StorageApi.GoogleDrive, System.String)'.
   at MusicBeePlugin.MainWindow.MainWindow_Shown(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnShown(EventArgs e)
   at System.Windows.Forms.Form.CallShownEvent()
   at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
Yes! Thank you!    :)    Works great now.
Speed on checking with plugin is reasonably fast now.
Uploading changes to repository was quick.
Speed for downloading updates seems to vary.  Update of 1 skin and 1 plugin went fast.
Updating of same skin with newer uploaded version was slow.   ???
Maybe would be better than for when no updates are needed?
yes, its better :) where did you take this icon?
some bugfixes, source code cleanup, new 'UpToDate' icon:
http://www.mediafire.com/download/xvjvdbx3bur31yu/mb_AddonManager_2015-08-03-3.zip
EDIT: plugin settings are added - go to edit> preferences> plugins
Last Edit: August 03, 2015, 06:23:46 PM by boroda74
Mr. Trev
Tried to give this a try. Don't know what I did wrong, but I get this error. Using version from above post
MusicBee v2.5.5690.35849 (Win6.1), 3 Aug 2015 11:09:
System.IO.FileNotFoundException: Could not load file or assembly 'System.Net.Http.Primitives, Version=1.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
File name: 'System.Net.Http.Primitives, Version=1.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
   at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)
   at Google.Apis.Auth.OAuth2.GoogleWebAuthorizationBroker.<AuthorizeAsync>d__1.MoveNext()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
suggest that you hadn't run 'Setup Add-on Manager' (as ADMINISTRATOR) from 'plugins' folder.
Icon from https://www.iconfinder.com/iconsets/fatcow
new icon shows in legend but not in column
reloading repository no longer updates existing files that have had changes made to them.
Items have to be deleted and then re-added and then repository updated to make a change.
also, what is maximum best or preferred size for screenshots please.  :)
Last Edit: August 04, 2015, 06:41:01 AM by Bee-liever
Mr. Trev
Nope did that - a couple of times, just to be sure.
After i click ok, the plugin seems to get stuck on the connecting process
