Greetings All,
Winamp used to have this really useful plugin called Playlist unpack. See
http://uploadgeneration.info/Winamp/www.winamp.com/plugin/playlist-unpacker/145249.html. I know that most of its function MusicBee can already do. The feature that I used the most was the one that allowed you to keep the playlist order of the exported files by inserting PL01, PL02 etc into the front of the filename. Unfortunately, this plugin doesn't seem to be compatible with MusicBee.
Is there any way that this function can be replicated in MusicBee? If not,
Is there currently a MusicBee plugin that does this? If not,
Do any of you programming types want to have a go at porting the plugin to MusicBee or create a similar plugin?
Rusecorbelia
