Author Topic: Win10 Style [Concepts] [Discussion]  (Read 222231 times)
Where can I DL this ?
"Th;is" meaning what exactly?  Where can you download the skin?  Or where can you download MB v3?  If the former, go back one page and look for the links.  But remember, this was a conceptual skin only.  I assume it works, but haven't used it.  If you're looking for MB v3 go here http://getmusicbee.com/forum/index.php?topic=17326.msg106325#new
KissCool
I really like how the tabs bar looks (1st picture of the 1st page). There's the same space between each tab's name (=/= same tab width) and it looks very neat.
Allowing us to reproduce this would be great.
But dunno how. Maybe, the easiest way would be to allow us to resize manually the tab width and the "lock tab" setting would prevent us from resizing accidentally the tab.
Or maybe an option to handle the tabs bar like the in-line menu bar ?
akhilsukh
I dont know what happened but the dropbox link didnt work, could someone send me a direct link asap
Alumni
Bitmap skin: https://dl.dropboxusercontent.com/u/10773406/DarkRED3.xmlc
Flat skin: https://dl.dropboxusercontent.com/u/10773406/DarkRED%20Flat.xml
You might need to right click the link and select "save as...".
The official thread for that skin can be found here; http://getmusicbee.com/forum/index.php?topic=10884.120
akhilsukh
im sorry, i still cant get it, it keeps saying download failed
it looks a lot like duophonic and monoural though.
endeavour1934
Downloads links here: http://getmusicbee.com/forum/index.php?topic=10884.0
akhilsukh
why does this look so much like duophonic and monoural?
Alumni
You can treat those skins as heavily modified versions of DarkRED. I originally created them for my own personal use. Of course endeavour deserves credit for the design.
akhilsukh
Hey Alumni, fonts did you use to make it look that great?
I just wanted to say thank you to endeavour1934 for putting together this proposal and all the people who helped with comments and testing. There are some really good ideas and its served as the basis for MB v3 which is released now.
Last Edit: May 11, 2016, 05:35:11 PM by Steven
serdontos
I'm trying to set my musicbee with this exact layout but i can't seem to get it right anyone know what settings i have to change because all this trial and error is for the birds
