Author Topic: Light Styles series  (Read 20385 times)
  • MB Version: 3.6.8849 P
ATTENTION!
This skin has been updated for MusicBee 3 and later.
Compatibility with version 2.5 or earlier is not guaranteed.
A range of light-toned skins, meant as a counterpoint to the included 'Dark' colour variation skins.
Light Styles
Asparagus
Colour Variants
Updates
September 23, 2017: now XMLC extension skins
  • MusicBee 3.1 changes incorporated;
  • added images for high DPI screens;
  • re-worked tabs bar, closer to the original 2.5 light colours;
  • icons updated;
  • new themed No Artwork and Unknown Artist images added.
July 3, 2016:
  • MusicBee 3.0 changes implemented;
  • skin border flattened and squared;
  • menu bar colours fixed;
  • splash screen, No Artwork and Unknown Artist images optimized to reduce file size;
  • icons updated;
  • scrollbars now use new lowlight settings.
Downloads
Download from Skins section of MusicBee Add-ons here.
This is a dependent skin series. Place the entire 'Light Styles' folder in your MusicBee skins folder.
If updating from the old .xml skins, please delete that folder before installing the new .xmlc versions.
Installation information, and more, can be found on the wiki
Last Edit: September 23, 2017, 01:21:09 PM by Bee-liever
Very nice, and good to see you're still going strong ;-)
One small comment: bg="255,255,255" for "Content[Artwork].Header" is probably a small oversight?
Thanks for the quick pick up on that, hiccup   :)
Files in link updated.
Wow! Over 100 downloads already!
But no one has told me their favourite colour yet.
de.cayed
Just downloaded this awesome skin tonight actually, and I'm currently debating between Quartz, Wisteria, and Teal Blue~
Last Edit: January 02, 2015, 01:33:56 AM by de.cayed
Yahh!  A response  :D
Quartz is one of my favourites too.  But I really like Wood Brown and New York Pink as well.
de.cayed
Yahh!  A response  :D
I'm using Outer Space now, I just can't make up my mind. XD
Updated for MB3
Download link and info in first post.
musicsnooper
Bee-liever I love your whole setup and customizations is there anyway to recreate it ?
There is currently no easy way to share MB setups. :(
I could share my settings.ini file, but it relies on quite a few custom tags, and you would need to do a lot of editing of the file for your library and devices to match back up.
fkm
Fantastic skin, really like it!
If there's only one request, it's that there's no really dark / black skin. The closest is Outer Space. Maybe consider this at some stage!
Did you happen to notice the name of this series of skins? They're called light for a reason.
There are many dark skins available. Look through the Skins forum and on the Wiki.
whismerhill
After a lot of pondering, between several skins wood brown got my vote ::)
whismerhill
hi,
so I just today upgraded to v3 & noticed some differences
I suppose it might have been reworked on purpose ?
in which case I'd like to ask if it's possible to get back the lighter colored A-Z jump bar ?
Thanks.
With MB3.0 the A-Z jump bar is now incorporated into the header bar and no longer a separate element so I can't put the lighter bar back in.
