i cant reproduce the same issues with playing a station from a playlist to a device. I can see a bug where its unnecessarily forcing transcoding to PCM when a station is played so i will look to fix that.
Does it work if you add the station to the Radio section of MB and play it from there?
hi, steven. as i said i had created a playlist called "myradio" with 8 radio stations within it.
this is where my trouble lies............
So i have done what you suggested and created a new radio station list and added the 8 stations within the radio section of MB.
and started streaming to the onkyo....
the problem is now that they all stop playing after 5 secs
also any station in the wma format wont play at all
many thanks
