Author Topic: UPnP/ DLNA device support  (Read 305999 times)
Hoofer
Anyone have any ideas as to why MusicBee cannot see any music files yet the TV sees the library just fine?  Please help.  Thanks.
Are you aware that the plugin adds server functionality, but it doesn't provide for client functionality?
Hoofer
Thanks for the reply.  The client side is in the smart TV and works fine with mediamonkey upnp but not MusicBee.  I can browse the library and play all of the music files, playlists, etc. with MM but when I run MusicBee it shows up on the TV just fine then when I select select Music it says that there are no music files found.  MM shows up the same way on the TV but when I select Music, all of my music files folders, playlist folders, etc, are on the screen and accessible?
Hoofer
Can anyone give me a steer on how to solve this?  The Samsung Smart TV client sees the MusicBee Library just like it sees the MediaMonkey Library but when I select the MusicBee Library from the TV remote it says that there are no music files in the library.  When I run MM and select the library from the TV remote everything work fine and I can browse, play, etc. from the MM library just fine.  I'd really like to move to MusicBee but I have to solve this first as it is my primary method of delivering music to my home theater audio system.  Many thanks in advance for any help.  I posted the log 2 or 3 posts back.
thomas2b
Hi from France !
Unfortunately, I face the same problem as #124.
I'm using the UPnP plugin to stream music to a Freebox (https://en.wikipedia.org/wiki/Freebox) connected to a basic Samsung TV.
Just as #124 described it, everything's fine until for no particular reason MusicBee starts eating up the CPU and RAM.
It eventually crashes with the following message :
" MusicBee v2.5.5804.26036 (Win6.1), 2 avr. 2016 15:22:
System.OutOfMemoryException: Une exception de type 'System.OutOfMemoryException' a été levée. "
I'm not sure what information I can provide, but I gladly will.
And now for something completely different, a little bit of personal history : I used Winamp (because it was Winamp) from time immemorial until it died, then used AIMP (because it looked like Winamp), then used MediaMonkey (because I was looking for a true music manager), then discovered and switched to MusicBee (because it's simply the best) :)
Orion
Hi from France !
Hi (from France too, but I feel obliged to write in English as long as we speak in "public").
I also reported a similar problem. Until Steven finds the time to fix the bug, I had to buy the Airplay plugin (10 €) to stream music to my audio amplifier. There is, unfortunately, a few second gap between the moment you click on the Play button on your computer and the moment the music actualy starts playing on the amplifier, particularly when for the first track, when your computer needs to connect to the amplifier. I just play a few seconds of a silent track and then my album. I didn't find any other solution.
You can try the plugin for 30 days : http://emilles.dyndns.org/software/out_apx.html
amper
Same here. Plugin was working like a charm with my Yamaha receiver, but after updating to latest version of MusicBee (2.5 branch) it simply consumes CPU and memory and dies with Out Of Memory exception few minutes later. I guess exe needs to be patched like the one in the first post.
Please Steve, make a new build for latest MusicBee 2.5/3.0 branches.
i dont think i have the bandwidth to maintain this plugin so if there are any developers interested in enhancing it please send me a PM
DRC3891
Hello, so I´ve used the plugin for about 4 months now and it had worked perfectly (even with Hi Resolution audio) but today it´s simply not working. The plugin appears in preferences but the DNLA server does not appear on my network (an any device) and the output options that the plugin enabled are now gone. I already tried to restart musicbee, reconnect to the network, reinstal thee plugin and even restart the computer but with no effect. Please Help.
amper
Is there any sources we can look into?
ruslakall
Ok this is probably not what you were referring to but I noticed after updating to MusicBee 3 that the output contextual menu shortcut I used to switch to a DLNA audio receiver moved from "Output To" to go under the "Play More" menu. So it became: "Play More>Output to"
Funny thing is now it's back to the "Output To"
Ralf
Hi Steven,
I just upgraded to a new internetradio Hama IR110 and have the same probs as before with the Freecom Musicpal: MB is startiing playback but after a short while it simply stops. I noticed that the Windows "Play to"-Feature is working nonetheless. Please find the last log below, perhaps it'll be of some use.
My config is Win10x64.1511 / MB 3.0.5595 / UPnP is 1.0.0.0 from 11.2.2015
1153272; 364 Profile - Generic Device, useragent=FDSSDP
1173444; 365 Profile - Generic Device, useragent=FSL DLNADOC/1.50 UPnP Stack/1.0
1173925; 366 Play - E:\Ralfs Musix\Simple Minds\1987 - Simple Minds - Live in the City of Light Disc 1\02 Big Sleep.mp3 (http://192.168.251.30:49382/files/80962078E08AE684p.mpeg)
1173965; 367 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
1173967; 368 GetFile[12] 192.168.251.30 - HEAD E:\Ralfs Musix\Simple Minds\1987 - Simple Minds - Live in the City of Light Disc 1\02 Big Sleep.mp3 to 192.168.251.28
1174054; 369 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
1174056; 370 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
1174057; 371 GetEncodedFile[13] 192.168.251.30 - HEAD E:\Ralfs Musix\Simple Minds\1987 - Simple Minds - Live in the City of Light Disc 1\02 Big Sleep.mp3 to 192.168.251.28; mime=audio/L16;rate=44100;channels=2,rate=44100,channels=2
1174084; 372 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
1174086; 373 Profile - Generic Device, useragent=NSPlayer/8.0.0.3801
1174088; 374 GetEncodedFile[14] - range=bytes 0-47131959/47131960
1174089; 375 GetEncodedFile[14] 192.168.251.30 - GET E:\Ralfs Musix\Simple Minds\1987 - Simple Minds - Live in the City of Light Disc 1\02 Big Sleep.mp3 to 192.168.251.28; mime=audio/L16;rate=44100;channels=2,rate=44100,channels=2
1174243; 376 StateTimer - Loading,old=Stopped
1174739; 377 StateTimer - Playing,old=Loading
1190391; 378 Profile - Generic Device, useragent=FDSSDP
1278823; 379 NetworkChange_NetworkAddressChanged -
1278862; 380 GetNetworkAddresses - 192.168.251.30,dns=True,name=Ethernet,speed=1000000000
1278863; 381 GetNetworkAddresses - 192.168.56.1,dns=True,name=VirtualBox Host-Only Network,speed=1000000000
1278864; 382 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
1278865; 383 GetNetworkAddresses - http://192.168.251.30:49382
1279806; 384 SyncNewPlayState - Stopped,mb=Playing
1279809; 385 NetworkChange_NetworkAddressChanged -
1279825; 386 GetEncodedFile[14] - exit=10054, playtime=105735
1279846; 387 GetNetworkAddresses - 192.168.251.30,dns=True,name=Ethernet,speed=1000000000
1279848; 388 GetNetworkAddresses - 192.168.56.1,dns=True,name=VirtualBox Host-Only Network,speed=1000000000
1279849; 389 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
1279850; 390 GetNetworkAddresses - http://192.168.251.30:49382
1282300; 409 Profile - Generic Device, useragent=FSL DLNADOC/1.50 UPnP Stack/1.0
1341891; 410 NetworkChange_NetworkAddressChanged -
1341981; 411 GetNetworkAddresses - 192.168.251.30,dns=True,name=Ethernet,speed=1000000000
1341982; 412 GetNetworkAddresses - 192.168.56.1,dns=True,name=VirtualBox Host-Only Network,speed=1000000000
1341982; 413 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
1341983; 414 GetNetworkAddresses - http://192.168.251.30:49382
1342899; 415 NetworkChange_NetworkAddressChanged -
1342932; 416 GetNetworkAddresses - 192.168.251.30,dns=True,name=Ethernet,speed=1000000000
1342934; 417 GetNetworkAddresses - 192.168.56.1,dns=True,name=VirtualBox Host-Only Network,speed=1000000000
1342935; 418 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
1342936; 419 GetNetworkAddresses - http://192.168.251.30:49382
1345294; 438 Profile - Generic Device, useragent=FSL DLNADOC/1.50 UPnP Stack/1.0
montharon
Hi Steven and all of you,
I know that there was already an inquiry about if it is possible to stream music to more than one device at the sime time and your answer was clearly no,
but I'm trying to stream my music to a pair of Sonos Play1 speakers that are combined as stereo.
When I first open MusicBee (latest version for the main application as well as your plugin) I can hear music from both speakers!
But when I close MucicBee and reopen it I get an error when I start the playback. "Unable to start playback (error=BASS_OK).
I also turned on the logging already
<?xml version="1.0" encoding="UTF-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:SetAVTransportURI xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><InstanceID>0</InstanceID><CurrentURI>http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483647.mpeg</CurrentURI><CurrentURIMetaData>&lt;DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:pv="http://www.pv.com/pvns/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"&gt;&lt;item id="0F59FEFCE2542E3C" restricted="true" parentID="0"&gt;&lt;upnp:class&gt;object.item.audioItem.musicTrack&lt;/upnp:class&gt;&lt;dc:title&gt;Rabbits On The Roof&lt;/dc:title&gt;&lt;dc:date&gt;2014-01-01&lt;/dc:date&gt;&lt;dc:creator&gt;Hundreds&lt;/dc:creator&gt;&lt;upnp:artist&gt;Hundreds&lt;/upnp:artist&gt;&lt;upnp:artist role="AlbumArtist"&gt;Hundreds&lt;/upnp:artist&gt;&lt;upnp:albumArtist&gt;Hundreds&lt;/upnp:albumArtist&gt;&lt;upnp:album&gt;Aftermath&lt;/upnp:album&gt;&lt;upnp:originalTrackNumber&gt;08&lt;/upnp:originalTrackNumber&gt;&lt;upnp:genre&gt;Pop, Rock &amp;amp; Alternative&lt;/upnp:genre&gt;&lt;pv:addedTime&gt;2016-05-07T04:56:50&lt;/pv:addedTime&gt;&lt;pv:lastPlayedTime&gt;2016-06-03T02:19:28&lt;/pv:lastPlayedTime&gt;&lt;pv:playcount&gt;1&lt;/pv:playcount&gt;&lt;upnp:playbackCount&gt;1&lt;/upnp:playbackCount&gt;&lt;upnp:albumArtURI dlna:profileID="JPEG_TN" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/"&gt;http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_TN&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI dlna:profileID="JPEG_SM" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/"&gt;http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_SM&lt;/upnp:albumArtURI&gt;&lt;res protocolInfo="http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000" duration="0:04:53" sampleFrequency="48000" bitsPerSample="16" nrAudioChannels="2"&gt;http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483647.mpeg&lt;/res&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</CurrentURIMetaData></u:SetAVTransportURI></s:Body></s:Envelope>
4115; 13 SoapRequest:SetAVTransportURI:urn:schemas-upnp-org:service:AVTransport:1:InstanceID=0,CurrentURI=http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483647.mpeg,CurrentURIMetaData=<DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:pv="http://www.pv.com/pvns/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="0F59FEFCE2542E3C" restricted="true" parentID="0"><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:title>Rabbits On The Roof</dc:title><dc:date>2014-01-01</dc:date><dc:creator>Hundreds</dc:creator><upnp:artist>Hundreds</upnp:artist><upnp:artist role="AlbumArtist">Hundreds</upnp:artist><upnp:albumArtist>Hundreds</upnp:albumArtist><upnp:album>Aftermath</upnp:album><upnp:originalTrackNumber>08</upnp:originalTrackNumber><upnp:genre>Pop, Rock &amp; Alternative</upnp:genre><pv:addedTime>2016-05-07T04:56:50</pv:addedTime><pv:lastPlayedTime>2016-06-03T02:19:28</pv:lastPlayedTime><pv:playcount>1</pv:playcount><upnp:playbackCount>1</upnp:playbackCount><upnp:albumArtURI dlna:profileID="JPEG_TN" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_TN</upnp:albumArtURI><upnp:albumArtURI dlna:profileID="JPEG_SM" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_SM</upnp:albumArtURI><res protocolInfo="http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000" duration="0:04:53" sampleFrequency="48000" bitsPerSample="16" nrAudioChannels="2">http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483647.mpeg</res></item></DIDL-Lite> - <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>1023</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>
4120; 14 Play:SetAVTransportURI - status=500,url=http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483647.mpeg
491981; 15 Play - N:\Musik\Alben\Pop, Rock & Alternative\Hundreds - Aftermath (2014)\08 Rabbits On The Roof.mp3 (http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483644.mpeg)
492006; 16 PostSoapRequest - 500,send=POST /MediaRenderer/AVTransport/Control HTTP/1.1
Host: 192.168.0.22:1400
User-Agent: MusicBee UPnP Plugin
Content-Type: text/xml; charset="utf-8"
SOAPAction: "urn:schemas-upnp-org:service:AVTransport:1#SetAVTransportURI"
Content-Length: 2191
<?xml version="1.0" encoding="UTF-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:SetAVTransportURI xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><InstanceID>0</InstanceID><CurrentURI>http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483644.mpeg</CurrentURI><CurrentURIMetaData>&lt;DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:pv="http://www.pv.com/pvns/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"&gt;&lt;item id="0F59FEFCE2542E3C" restricted="true" parentID="0"&gt;&lt;upnp:class&gt;object.item.audioItem.musicTrack&lt;/upnp:class&gt;&lt;dc:title&gt;Rabbits On The Roof&lt;/dc:title&gt;&lt;dc:date&gt;2014-01-01&lt;/dc:date&gt;&lt;dc:creator&gt;Hundreds&lt;/dc:creator&gt;&lt;upnp:artist&gt;Hundreds&lt;/upnp:artist&gt;&lt;upnp:artist role="AlbumArtist"&gt;Hundreds&lt;/upnp:artist&gt;&lt;upnp:albumArtist&gt;Hundreds&lt;/upnp:albumArtist&gt;&lt;upnp:album&gt;Aftermath&lt;/upnp:album&gt;&lt;upnp:originalTrackNumber&gt;08&lt;/upnp:originalTrackNumber&gt;&lt;upnp:genre&gt;Pop, Rock &amp;amp; Alternative&lt;/upnp:genre&gt;&lt;pv:addedTime&gt;2016-05-07T04:56:50&lt;/pv:addedTime&gt;&lt;pv:lastPlayedTime&gt;2016-06-03T02:19:28&lt;/pv:lastPlayedTime&gt;&lt;pv:playcount&gt;1&lt;/pv:playcount&gt;&lt;upnp:playbackCount&gt;1&lt;/upnp:playbackCount&gt;&lt;upnp:albumArtURI dlna:profileID="JPEG_TN" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/"&gt;http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_TN&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI dlna:profileID="JPEG_SM" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/"&gt;http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_SM&lt;/upnp:albumArtURI&gt;&lt;res protocolInfo="http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000" duration="0:04:53" sampleFrequency="48000" bitsPerSample="16" nrAudioChannels="2"&gt;http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483644.mpeg&lt;/res&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</CurrentURIMetaData></u:SetAVTransportURI></s:Body></s:Envelope>
492012; 17 SoapRequest:SetAVTransportURI:urn:schemas-upnp-org:service:AVTransport:1:InstanceID=0,CurrentURI=http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483644.mpeg,CurrentURIMetaData=<DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:pv="http://www.pv.com/pvns/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="0F59FEFCE2542E3C" restricted="true" parentID="0"><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:title>Rabbits On The Roof</dc:title><dc:date>2014-01-01</dc:date><dc:creator>Hundreds</dc:creator><upnp:artist>Hundreds</upnp:artist><upnp:artist role="AlbumArtist">Hundreds</upnp:artist><upnp:albumArtist>Hundreds</upnp:albumArtist><upnp:album>Aftermath</upnp:album><upnp:originalTrackNumber>08</upnp:originalTrackNumber><upnp:genre>Pop, Rock &amp; Alternative</upnp:genre><pv:addedTime>2016-05-07T04:56:50</pv:addedTime><pv:lastPlayedTime>2016-06-03T02:19:28</pv:lastPlayedTime><pv:playcount>1</pv:playcount><upnp:playbackCount>1</upnp:playbackCount><upnp:albumArtURI dlna:profileID="JPEG_TN" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_TN</upnp:albumArtURI><upnp:albumArtURI dlna:profileID="JPEG_SM" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/">http://192.168.0.53:49382/thumbnail/0F59FEFCE2542E3C.JPEG_SM</upnp:albumArtURI><res protocolInfo="http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01700000000000000000000000000000" duration="0:04:53" sampleFrequency="48000" bitsPerSample="16" nrAudioChannels="2">http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483644.mpeg</res></item></DIDL-Lite> - <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>1023</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>
492020; 18 Play:SetAVTransportURI - status=500,url=http://192.168.0.53:49382/encode/0F59FEFCE2542E3C-2147483644.mpeg
After the error occured I must pair my speakers in the official Sonos controller again otherwise they act as mono speakers for their own ;)
Any suggestions?
Thanks in advance!
Mike
kairosmatt
Hi Steven and everyone,
   I have been using MB for about a year and love it-thank you for your efforts!
I have spent the day trying to figure out the music streaming thing, specifically to a PS3. I am brand new to it and there was, and still is, a lot to figure out so I'm sorry if these are obvious issue but I can't figure them out myself.
Main hurdle was I am using ATT U-verse, so I don't have UPnP and have had to set all the ports and static IP addresses. I got through that and MB shows up on the PS3. I'm not sure if that set up lead to my two issues:
1) Browsing for files is very slow on PS3. it takes a long time to load each folder's contents. Also there is significant lag between songs and between pressing a button (next, pause etc) and the result happening. It seems to be in the 10-15 second lag range.
2) I cannot figure out how to get MB to stream to the PS3. It does not show up in the player output device or any contextual menus. Can I manually help MB find the PS3?
Are these two issues related, and if so is there anything I can change or set up to streamline the experience?
Thank you so much!
kairosmatt
doane
This plugin supports server mode (enables UPnP devices to browse and play from the MusicBee library) and controller mode (playing from MusicBee to UPnP devices)
Unzip and place in the Plugins sub-folder
http://www.mediafire.com/download/8oqz833v9z364da/mb_Upnp.zip
There are quite a few configuration options that can be set via the Configure button in the plugins panel which should be straight-forward - ask if you are not sure of something.
I have been warned that there are a lot of buggy UPnP devices which will require work-arounds. If your device is not being detected then first check with some other software which you know works with your device. If you cannot get the plugin to work or are getting odd behavior, then enable the debug log which is an option in the configuration screen and after restarting MusicBee send me the log file that is generated when playing a track. Keep in mind I have only implemented access from within your home network for now, so if you are trying to communicate outside the network it wont work.
I have made an attempt at supporting access from X-Box devices, so if anyone has one i would be grateful if you try it out and confirm if it does work. PS3 have been confirmed as working, as have various UPnP output devices
I found the plugins window under the preferences window in MB, but I don't see the "configure button" for this plugin?? I unzipped the folder mb_Upnp that has the dll file in it and put it in the plugins folder under the program. I have MediaMonkey and it works as a server with my Samsung TV and I can see and play all files from it along with playlists, but I would rather switch over to MB if I can get this to work.  Thanks,
Never mind, I got it to work, I had to extract the zip directly to the plugins folder and it just put the dll there, not the folder with the dll in it. Now I have the configure button in MB, will see if I can get this to work
MB shows up in the TV, but when I open it and choose the Music, I get an error that there is no music available on the MB server. I tried several different versions including Generic and Windows and the Upnp, but none work
I tried Upnplay selection with the logging. Restarted MB and tried to connect and got the same error of no music files available. Here is the logg:
838318; 1 Profile - Generic Device, useragent=SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50
3; 1 Initialise - 9/10/2016 2:53:57 PM
16; 2 GetNetworkAddresses - 192.168.0.21,dns=True,name=Local Area Connection,speed=1000000000
18; 3 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
19; 4 GetNetworkAddresses - http://192.168.0.21:49382
143; 5 ProcessMessage 192.168.0.23 - device 'uuid:08583b02-008c-1000-8d84-84a466b311c3:[TV]Samsung LED65',valid=True
612; 6 ProcessMessage 127.0.0.1 - device 'uuid:0b6e3f16-e440-49b9-ae0b-acd3a7c45552:Doane (DOANE-PC : Windows Media Player)',valid=True
1500; 7 Profile - Generic Device, useragent=SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50
21598; 8 Profile - Generic Device, useragent=SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50
21615; 9 Browse - 1,BrowseDirectChildren,0,1,sort=
21700; 10 Proceed Control - Exception has been thrown by the target of an invocation.
"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>1</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>
21703; 11 Proceed Control - Object reference not set to an instance of an object.
   at MusicBeePlugin.Plugin.ItemManager.LoadNode(TemplateNode template, FolderNode& folder, Boolean drillDown)
   at MusicBeePlugin.Plugin.ItemManager.TryLocateNode(String[] objectIds, TemplateNode& node, FolderNode& folder, Int32& lookupIdCount)
   at MusicBeePlugin.Plugin.ItemManager.Browse(Dictionary`2 headers, String objectId, BrowseFlag browseType, String filter, Int32 startingIndex, Int32 requestedCount, String sortCriteria, String& result, String& numberReturned, String& totalMatches)
   at MusicBeePlugin.Plugin.ContentDirectoryService.Browse(HttpRequest request, String ObjectID, String BrowseFlag, String Filter, String StartingIndex, String RequestedCount, String SortCriteria)
21704; 12 ProcessRequest:SoapException:501 - Action Failed
   at MusicBeePlugin.Plugin.UpnpService.ProceedControl(HttpRequest request)
   at MusicBeePlugin.Plugin.HttpServer.ProcessRequest(Object parameters)
63877; 13 Profile - Generic Device, useragent=SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50
63878; 14 Browse - 1,BrowseDirectChildren,0,1,sort=
63882; 15 Proceed Control - Exception has been thrown by the target of an invocation.
63885; 17 ProcessRequest:SoapException:501 - Action Failed
Last Edit: September 10, 2016, 10:59:56 PM by doane
