Author Topic: Discogs Tagger  (Read 108173 times)
crap_inhuman
I  only need the api binary.
I would use the Discogs Tagger written with AutoIT.
Metal up your ass !
OOmatrixOO
Hi.
Any news about a good working tagger?
Mr. Trev
How do you force MusicBee to request a new key?
I was using a portable install for a bit, and got a new key for it, but now my standard install won't access the Discogs database. I've tried reinstalling the plugin, and revoking access from Discogs hoping I'd get a new PIN but nothing so far
Havokdan
Deleting the file "discogs.token" which is in the folder "C:\Users\UserName\AppData\Roaming\MusicBee\"?!?
Mr. Trev
Tried moving that file to my desktop, but still no joy. The only tag source I'm getting any info from is Musicbrainz
that is the file to delete. But if you are running a portable version then its in the AppData sub-folder where MB is installed
Mr. Trev
Not sure why, but it just took a couple of launches before it requested a new PIN after I deleted the file.
Guess I should stop trying to use a portable and full install at the same timeā€¦
Cheers
t0mekk
great plugin, but it worked only few times :/ for now its useless.
tried uninstalling, refreshed pin, nothing seems to work.
full install musicbee 3.0.6070
win10 x64
rudolph
win10 x64
It works for me..
Version: 3.0.6077
You have to enable it in preferences > plugins if you haven't done that, and then wait (or start auto-tag) when you will be requested to accept the API key on discogs website.
Hualgom
So.. If I want to tag my files with this album https://www.discogs.com/es/ABBA-ABBA/release/465186 why I can't put the code -> r465186 anywhere to tag exactly that album?
I can't find it inside MusicBee, It's impossible.
I don't understand why if I put ABBA - ABBA just show me 1 album, but if I put one song in the album it shows me a few more (but not the one I am interested). It doesn't show me one single album from 1975 (the original date) nor the correct record company of the album: Polar Music (original release), but that data exist:
https://www.discogs.com/es/search/?type=all&title=ABBA&artist=ABBA&label=Polar&track=&catno=&barcode=&anv=&format=&credit=&genre=&style=&country=&year=1975&submitter=&contributor=&advanced=1
How could I do that? How do I get to any of that albums in MusicBee?
Last Edit: October 28, 2016, 10:34:57 AM by Hualgom
@ganamide, i have split the discussion and moved to the developers area
djdalex
I do all my tagging by hand or with Tagscanner. Discogs tagging in MB seems to be unstable or not able to find the right release. I can do it quicker by hand and Tagscanner also does a great job. Would love to see a good working plugin for MB!
Vinyl lover / Vinyl ripper / Vinyl cleaning / Digitizing addict / Audio repair / Audacity lover / Clickrepair.net lover / MusicBee Newbee
solar
This doesn't seem to work at all. It was working in the last moth up until today I think.
Really useful plugin I hope you can get it to work.
MB v3.0.6276
Its also working today. I suggest you try again later.
If you still have issues, i wont be able to help
