Author Topic: Coloured Toolbar Icons  (Read 15148 times)
  • MB Version: 3.6.8849 P
Still a work in progress.
These are the icons I have done so far:
I have included four "external application" tools.
Download available here
Updates
August 30, 2014:
  • left, right and playing track panel icons added;
  • some Tools: icons done
  • custom search and compact player re-imaged for greater clarity
Last Edit: August 30, 2014, 04:31:55 AM by Bee-liever
some more icons done, including toggle panels for MusicBee 2.4
romney_yw
I've just stumbled across your toolbar icons, which I like a lot.
I've tried using some of them, but unfortunately they appear as monochrome, or in several cases a just blank grey square.
I suspect that this might be because I'm using Steven's Spotify B skin? In general, I prefer a darker skin and this one seems close to perfect - though there are a few minor details which I might try tweaking - if/when I get round to experimenting with skins myself.  :)
Do you know whether it is possible to make your buttons appear as designed using this particular skin, or is something in the skin design restricting me to monochrome (for the time being at least)? I'll do some more experiments when I get a moment or two.....
Colour introduced using Highlighting Rules seems to work OK, but I realise that this is not quite the same thing.
Thanks very much for the buttons. I'm sad that it seems I can't use them with my current configuration.
right-click on the icons toolbar> Configure Toolbar
un-tick 'adjust icon coloring to match the selected skin'
romney_yw
Thank you very much. I guess I really should have noticed that tick box for myself! :-[
 :D  No worries.  We all have those moments.
