Author Topic: Support for sending song info to instant messengers should be added  (Read 14407 times)
i think it is a good suggestion and I am sure others will want this. I have a lot of things to do at the moment but maybe late next week i can investigate what is involved before i commit to this
not exactly what you asked for but i have included a 'Send to Clipboard' option in the right click action.
it uses whatever fields you use for the track info panel (by default artist, track title, album and year) and copies that data to the clipboard so you can paste into your IM.
Let me know if this will suffice
http://www.mediafire.com/?eodjjfmmzwy
Maleko12
I love Digsby! I love this feature that it supports...
Here's a picture of what Zero3K is talking about via iTunes:
chorpo
How about emulation of winamp so MB will be recognized as Winamp (Digsby would then change now playing text ;) ). This one should do the trick -->>> http://yiting2002.myweb.hinet.net/rainmeter/winamp_ipc.html
peter
chorpo, thanks for the info - i will check it out and also contact digsby to see if they have an API that i can call
just to let you know i contacted digsby last week but havent had any reply
zero3K - do you have any email addresses or names i can contact there? i just used there general email address but it might help if you know the name of a developer there
