Hi Bee-liever
Thank you, for all your beautiful creations across the site.
I am experiencing a problem after installing my first ever TheatreMode [TM] view, in this case, Mod'ernairre, and I hope you can assist me to sort it out. My first guess is that I have installed Mod'ernairre incorrectly at the very beginning- probably due to not properly comprehending the
Wiki-install guide.
This is how I installed the Theatre Mode, and the sequence of events:
1.] I created two sub-folders in MusicBee > Skins
2.] Inside the Skins folder, I created two sub-folders called:
2.1] TheaterMode.Embeded "sic"
2.2] TheaterMode.List
3.] After downloading it, I extracted Mod'ernairre to the latter folder.
4.] I access Mod'ernairre via the MusicBee Menu > View > Skins > TheatreMode.List > Mod'ernairre
5.] Upon clicking on Mod'ernairre, a MusicBee restart is initiated, but fails due to an "exception" error, that reads:
The type initializer for '#=qaeYoNAAo4O6oP6qr1XdlCIsqBo3iBfcd2QI5nR3P9bA=' threw an exception.
6.] Renaming the two TheatreMode sub-folders [2.1, 2.2] gets MusicBee started again.
7.] My PC is equipped with Windows 7x64, and the MusicBee version is v3.1.6477.
Noteworthy: I have tried two other TM Views now, with the same results, hence my guess that I most probably have an install error at hand, but how do I correct it?
Thank you.
