Author Topic: CalciumMETRO & MidnightMETRO  (Read 28436 times)
Thanks for sharing these. Great work!
BTW I'm not sure the red border color for TabsBar.TabInCaptionBar.Highlight was intended.
mikebo
No it wasn't, thanks for reporting that. I've made some changes to the tabs in caption bar and the menu button.
lnminente
Hi Mikebo, i was trying to update my mod from your dusk and looking for how to skin love icons i found this skin from yours and i really like it a lot. In fact i'm think in abandoning the dusk.mod and porting my tweaks to this base.
The thing why i arrived to this skin: When we select a not loved track in main panel and put our mouse over the not loved heart, it turns lighter.
I would like that when we do it in a loved track, it would become darker. I tried in my dusk.mod but didn't was able to do it, neither in this base, neither in the .xmlc. Maybe there is a bug i should report to Steven?
BTW I have realized in your base LastFmLove and LastFmNotLove are the same icon.
TIA!
Last Edit: January 27, 2014, 11:41:18 AM by lnminente
mikebo
I'll upload the source files for you later.
I'm not sure what the issue with love icon is but there sure were some quirks last time i looked at it. If you think there is a bug worth fixing then you should tell Steven.
Last Edit: January 27, 2014, 07:50:08 AM by mikebo
lnminente
Hi Mikebo, i did some modifications to your great base skin
Sorry, i didn't log the changes, it's here: http://www.mediafire.com/download/q9g2n9cba9m3trt/base+midnight.metro.mod+140215.xml
EDIT 140218: I think most changes in the base xml are visible in the following picture:
Last Edit: February 18, 2014, 07:07:18 PM by lnminente
lnminente
Hi Mikebo, Klint reported me a bug with these skins when opening the dialog Tool\Download artwork.
The problem is the use of transparency in the following element: <element id="Controls.ArtworkFrame" bdr="40,255,255,255" />
Klint reported it here: http://getmusicbee.com/forum/index.php?topic=6036.msg73401#msg73401
mikebo
Small update supporting recent layout changes.
Alumni
Hi mikebo, can you please update the source file with the recent changes you made?
mikebo
Orion
First of all, congratulation for your skin, Mikebo. It's by far the best available, in my opinion.
Yet, I have a problem with my progress bar, which is not displayed the way it should (like on the screenshots above). Do you know how to account for it ?
I must add that I currently use MusicBee 3.0 beta version.
Thank you very much in advance.
Last Edit: March 07, 2016, 05:13:42 PM by Orion
mikebo
Thanks for the kind words. What dpi setting are you using?
