Author Topic: Google Play Music Access  (Read 108022 times)
lucfig
Nice work.
Before I deleting my Google Music library I would like to know if this plugin will sync playcounts and ratings with Google Music.
At least when uploading the first time, will it upload ratings and counts?
Thanks in advance
klint
Hello
I have installed the plugin with the very latest version of MB. The menu option is here, "Turn GPlay Music Access On", but it does nothing when clicking on it.
Also, the settings window looks weird: http://vvcap.net/db/5ttyTNSTW-H_Q44Xiapw.htp
What is the isolated check box for?
Thanks for your help
Olivier
Hello
Strange. I've recompiled and reuploaded plugin. Try new version
http://www.mediafire.com/download/mjja8d9dfy2cjvu/mb_GooglePlayMusic_2013-11-13.zip
Its 'Turn on Google Play Music Access on startup'. Its fixed now.
klint
Hi again
Thanks, I will try the new version on my home computer.
On my work computer though, I have another issue: the authentication page opens correctly in the browser, and the login box opens, but I can't key the @ char in the password field :)
Thanks
I'm afraid I cant help you with this issue.
klint
I have tested with the recompiled version, the entry in the settings now appears ok, but still no login box nor authentication site page :( Is there a log file anywhere?
On the other computer - on both computers actually, about the @ sign, I just have noticed that I cannot enter it in any field in MusicBee actually: so it's not only this plugin. Can you reproduce that on your end? I have a French keyboard, it that matters...
Thanks again
klint
Ok, issue with @ solved: on a French keyboard, that oddly stands for a MB default shortcut!
I am connected properly now on the second computer.
Try to click 'Logout' button in plugin settings window and restart MB.
klint
Moshi_
  • http://www.last.fm/user/Moshi_
How exactly do I upload songs to Google Play from MusicBee?
And delete from MusicBee?
I would recommend to create a static playlist 'Google Music', add tracks to upload to this playlist and sync this playlist. You can set playlist to sync in Google device properties. Or if you have less than 20000 track in your library you might sync whole library. Also you can create several playlists for uploading and sync all of them.
If you delete tracks from synced playlists and check 'delete tracks that are not on auto-sync list from device' in Google device properties then deleted from playlists files will be deleted from online library.
Moshi_
