Author Topic: Google Music Playlist Sync  (Read 23610 times)
leo_r
Have you followed the instructions on the wiki regarding enabling third party apps to log in to your Google account?
Claytton
Yes
offtheleft
Hey Leo, still having issues syncing in from Google Play to MusicBee.
offtheleft
Figured out my issues! I had to create empty playlists with the same names as my Google playlists, and they synced the songs into the empty playlists. Kinda clunky, but hey, it worked!
leo_r
Hi! Sorry for the general delay in replying. I've put out a new version which should successfully sync both ways.
Download here
The Chauffeur
I can't log in
Have you solved this problem?
I finally installed 2.5 incl. GM-Sync, but can`t log in either.
Google Account Login for Less Secure Apps was already enabled.
No idea what to try now...
olliebean
Having a problem with this that I haven't seen anyone else mention.
The first time I run MusicBee after installing the plugin, it appears to work fine - the only issue is that when I log into Google Music, I briefly see a message: "ERROR: couldn't save settings", but then my Google song list downloads and I can sync playlists with no problems. But the next time, and every subsequent time I run MusicBee, I get the following error when trying to start the plugin:
MusicBee v2.5.5524.39432 (Win5.1), 20 Jun 2015 22:29:
   at MusicBeePlugin.Configure..ctor(PlaylistSync playlistSync, Settings settings)
   at MusicBeePlugin.Plugin.onMenuItemClick(Object sender, EventArgs e)
   at #=qOQLu0JmgzQo$2ZdDrQQe12OrwXflzNjHEoSdrrSwLsPsSNmq$_gZyqD7qVQ4rQww.#=qFqKrvY1c320y93RWz_d7Pg==(Object #=qRzfhR_ZoP4ghNlUG9SvRag==, EventArgs #=qPphfixBs9dCqakgxrq5Oeg==)
I can get it working again if I go into my MusicBee\AppData folder and delete MusicBeeSettings.ini (or restore a previous version from a backup) and gMusicPlaylistSync.Settings.xml (which is a 0 byte file); but obviously this isn't ideal.
Any ideas what's going wrong?
Tmel
I can't log in
Also have the problem of not being able to log in despite enabling Less Secure Apps.
Anyone manage to solve this?
boroda74
Google has completely shut down Client Login API recently. Maybe this is the issue?
Silvaire
I can't log in either.  I assume it is a Google API issue as mentioned above.
Someone, apparently the developer of this plugin, confirms on the wiki that the API is deprecated.
mythichelm
I updated the plugin with a new GooglePlayMusic client that uses the new login flow. I'm not the original dev, and I just updated this for personal use, so if something breaks, I can't promise I'll fix it. From my own personal use of it, everything seems to be working, but feel free to try it out.
Download plugin here:
https://github.com/mitchhymel/MBGmusicSync/releases
My fork of code for plugin:
Code for GooglePlayMusic API:
https://github.com/mitchhymel/GooglePlayMusicAPI
