Author Topic: DarkRED  (Read 187269 times)
forfrosne
Hi, thank you for this.
How do I install the icon pack?
Thank you.
theta_wave
Thank you.
I believe icon packs are unzipped or unrared to C:\Program Files (x86)\MusicBee\Icons
klint
Hi
There seems to be a slight vertical offset for the highlighting of a subscription row in the Podcast panel in MB 3.0: the orange part is not centered vertically (as it used to be in 2.5).
See here:
Thanks
Hi
thats a bug that i need to fix
Last Edit: October 17, 2016, 08:22:36 PM by Steven
klint
skyrockman
how do i get the layout you have in your screenshot?
thats almost the default layout for musicbee 3.0
Assuming you are using that version i suggest you check the wiki:
http://musicbee.wikia.com/wiki/The_Anatomy_of_MusicBee
Tommy
....... is it possible to get the XML file for this skin ?
Tommy
.xmlc skins are compiled - there is no xml available unless the author provides one to you and then you change and recompile it. The first post states that the flat version of the skin has xml available along with the link.
Tommy
....... thanks for your reply.
Sorry, I missed the link at the beginning of this thread.
Got it now and thanks again .......
Tommy
shrubberer
Hate to look like I'm asking an answered question, but does anybody have updated download links or mirrors for the .xml files? It looks like all the Dropbox files have been moved; they all just 404.
Cheers.
brainvision
hi there guys, is this theme still good for 3.1 builds?
thanks..
endeavour1934
thanks..
I'd like to know the answer to that as well...
thanks..
the only thing i can think of is there is a new device icon in the header bar. I do plan to do some skin enhancements from the requests topic in the near future
